Outboard
DevonPhotographer
11 Aug 2011
Torbay Devon
Hey guys
So I have my tohatsu 3.5 2 stroke clamped to my chair in my kitchen and it's been there for a week or two, I woke up this morning to find about 1cm of dark black oil on the kitchen floor, can anybody tell me what this is I can't seen to find where it's leaked from? Thanks
Kris
William_H
28 Jul 2003
West Australia
Oil from O/B
The oil is most likely from the gearbox. There is a seal at the prop shaft and of course seals at the drain and fill holes. You need to examine the motor to see where it is escaping from.
Check the level of the gearbox oil.
However there is just the chance that the oil (or whatever) is coming from the exhaust tube as a combination of soot 2 stroke oil and possibly water. good luck olewill
VicS
13 Jul 2002
It is quite normal for a two stroke to "leak" black partly burnt oil from the exhaust outlet.
Look to see where it has come from, if from the exhaust no worries.. It will smell burnt too, of exhaust fumes, possibly even of petrol as well .
Oil from the gear box should not be black! it should be straw coloured and have the characteristic rotting cabbage smell of an EP oil.
If it is gear oil you need to be replacing some seals !
If it is gear oil and is black you have some serious maintenance to do.
When you change your gear oil each year note its condition. It should be "clear and bright". If it is milky it indicates water ingress through a defective seal
Read this item on the iBoats forums about oil leaking around the lower unit
http://forums.iboats.com/showthread.php?t=207285
Jim@sea
12 Feb 2010
Glasson Dock
Hey guys
Kris
If I put my outboard on a chair in the kitchen for a week or two, as well as dark black oil on the kitchen floor there would also be a pool of something red, sticky, coagulates and we only have 8 pints of it.
