LONG_KEELER
I have changed the water pump impeller on my Mariner 6hp 4 Stroke 2008 outboard.
I just can't get the leg back on the outboard. You have to marry up the drive shaft into the splines, water pipe connection and gear rods.
The problem seems to be meshing the splines together. I'm about two inches short. I have tried turning the prop by hand when offering up the drive shaft but she just won't go. Do I need the gear lever in a particularly position when offering up and or perhaps tie it off ? It's very difficult to see anything with a torch and it's a long shaft.
Any tips would be most grateful received.
