Kelpie
Here's a 1.5hp outboard...
https://www.alibaba.com/product-detail/One-Cylinder-Small-Outboard-Motor-4_60327941181.html
What I don't get is why it's boat engines that are affected by this, and not strimmers, mowers, etc etc, of which there must be hundreds of times more in use.
And equally why you can still buy two stroke outboards provided you can certify it's for 'business use'.....
Suzuki 2.2hp 2-stroke: 12kg![]()
Polluting the back of your car by dribbling some oil out is not in any way the same as emitting a fine mist of unburnt carcinogenic particles into the air from a two stroke's exhaust.
I wouldn't totally pooh-pooh the Torqueedo, but the price makes it an irrelevant curiosity from my point of view. I see no benefit whatsoever in switching to a small 4-stroke.
See Dylan’s website.
My hope is that other manufacturers will cotton on and produce electric outboards in a less gold-plated way. Do battery packs really need to have GPS receivers built in?
Dont buy one. You will be lucky to get an hours usage from it
Good point, the GPS in the Torqeedo is needed to help it calculate range, speed, etc. GPS chips are, well, as cheap as chips anyway, so won't add greatly to the cost.
True. And the battery is only (sic) £499. Which, since the whole thing costs £1,699, means that they are charging an £1,200 for an electric motor, some control electronics and some injection moulded plastic. And, of course, for the development costs. And, of course, if the market will bear it yadda yadda yadda.
I'd buy one like a shot at £500. At £1,000 I'd have to tussle with my conscience for a few weeks. At £1,700 ... no chance.
What is the life of a battery for the Torqeedo?
On the Seamark Nunn site it stated that the battery might lose 4% of capacity per annum - and more if used a lot in the heat (not an issue in Scotland!) or “if left fully charged for long periods” - apparently it should be left only 50% charged.
My Mariner 2 stroke must be 20 years old now but running perfectly well. A battery losing 4% per annum, as a best case, would need replacing at least every 10 years - and seems impractical to store at 50% as generally will want to have fully charged and ready to go.
Anybody got a Torqueedo over 5 years old able to comment on battery capacity?
£1700??? Not sure where you generally buy stuff, but if you think the Torqeedo costs £1700 it's no wonder you don't think you can afford one! Currently, the 1003S is £1340 at Seamark Nunn, and probably cheaper elsewhere.
Thanks. If you clink on the links in my post you'll see that I was going by the direct-order prices from Torqeedo.
You can't buy one anyway - minimum order is 50 units!![]()
That is a great pity (50 units!)
Why do you say only an hours usage?
Ah.
Thanks for the warning.
Pity, looked just the ticket.
