seadog30
I have a rarely used Tohatsu 3.5 HP 4 stroke, on the one or two times a year it has been used it has always been a good starter.
While checking it over (no point having a spare that does not work) it would not start.
After checking fuel circuit, jets etc I took out the spark plug and found no spark.
The usual suspect for electrical faults is the safety cut out switch, tested no faults, I changed the spark plug for a new one and made sure that all the connections were OK.
Am I correct in thinking that the fault must be in the encapsulated ignition coil ?
Regards - Seadog.
Regards - Seadog.
