Jeesa
Hi. My outboard started lifting up while reversing. I had a mechanic look at it and the rotary bracket was bend. He tried to fix it and it was running fine. But now the issue came back. He said that he had to compromise and fitted the bracket around the tilt rod assy. But then we couldn't lift the motor up at all to get to the propeller which we found out later.
Exploded view: Bracket Parsun F9.8 outboard. Spare parts and exploded view
The rotary bracket is no. 41, the tilt rod assy no. 8.
I would be happy to order the replacement rotary bracket but after my experience with the mechanic, I am not sure if this will solve the issue. Also, the bracket or any other part did not look broken just a bit bend. Maybe it only has to be adjusted correctly.
Any advice is appreciated. Thank you!
