outboard ignition
sessanta
New Member
26 Aug 2007
Is there any electronic ignition kits available for 2cyl 2stroke outboard engines. It would be of benefit for owners of older small HP engines ( around 1980s)
I have no idea but is this worth investigating?
ELECTRONIC TRANSISTORIZED IGNITION MODULE NOVA II
https://www.amazon.com/ELECTRONIC...IGNITION-MODULE.../dp/B007BI6FW6
Rating: 4.3 - ‎92 reviews
Buy ELECTRONIC TRANSISTORIZED IGNITION MODULE NOVA II: Control Units ... Easy to install compact design For most 2 and 4-cycle engine applications, ..... on an older outboard that is hard to get parts so didn't get the motor running but it ... Briggs & Stratton 394970 Ignition Kit used to Retrofit most 2-legged Ignition ...
Are there many outboards with mechanical points still running? I would have thought that most of them had long since gone to meet their maker, Seagulls excepted? :ambivalence:
Richard
I had a 5HP air cooled Cresent a few years ago that was as good as gold. I cleaned the points, adjusted them to give the correct timing and it started and ran very well.
I did replace the shear pin-it had a bit of old nail in the drilling......................................
