Outboard gear Q 25HP Johnson
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
External lever on the console rotates a 3 toothed contraption, FNR on the front of the OB inside the cowling
When N is set on the centre stud F works, but no R
So the 3 toothed contraption has to be set off centre, not in 'N' for the gearbox to work properly
I assume the external indicator and the gearbox are out of sync ?
Can I 'just' adjust something near the gearbox or is this a leg off / mechanic job ?
You give no clue a the identity of the engine. There have been countless variations of 25hp Johnsons over about 1/2 century
If no joy here I suggest you post your query on the Johnson and Evinrude board of the iBoats forums at http://forums.iboats.com/forum/engine-repair-and-maintenance/johnson-evinrude-outboards
but QUOTE THE MODEL NUMBER!
