chris-s
We recently added a new Tohatsu 6hp outboard to our sailboat and positioned the external fuel tank in the sole locker just in front of the engine but I think it might be too low with the base of the tank about 23 inches below the fuel line connection on the engine as we are having an odd issue. All the pipework, fittings and tank are new too, and new fuel.
We hate motoring but sometimes you just have to and of course as engines do, when they decide to stop they pick the most inappropriate time like the middle of a mooring field.
After running for about 20 minutes, the revs begin to drop off and we need to reprime it, after which it picks up and runs fine again but then needs repriming every 5 to 10 minutes. It's clearly a fuel supply issue. If we don't prime it, then it will cut, but restart instantly after priming. It will tickover with no load for ever, but the problem occurs almost regardless of the revs we have been running at.
We've checked for any obvious leaks, the pipe between the filter and carb was a little and looked a bit kinked, so shortened that no difference. The hose between tank and engine was a little long, so we removed nearly 4 feet so it's now about as short as it can be to go pretty direct to the engine, <3 feet, no difference.
It's not the vent, which is remote as I removed the cap in one test. Sea state makes no difference.
So yesterday, we took a second new tank and hose setup with us to try out. Firstly the existing setup behaved exactly as before, 20 minutes in and splutter. We switched tanks with the second one being on deck, and it ran faultlessly for 40 minutes until we went from <3 knots of wind to 25 and could pull out the sails.
Next time out we will swap the tanks around to eliminate anything specific to the tank or it's pipework. But at the moment it's looking like the tank is too low, which will be a real pain to relocate it to one of the cockpit side lockers which aren't exactly spacious to start with.
Do you think it's too low?
Chris
Chris
