Elessar
Prop walk is more pronounced with big-pitch props. A 30 knot outboard boat might typically have a prop of around say 15inches pitch while a twin diesel big shaft drive P motorboat might have a prop pitch in the order of 45 inches, so you will have much more prop walk with the latter (at the same idle rpm of say 300-350rpm at the prop). All my numbers are ballpark, obviously.
Prop diameter as well J.
The bottom is in higher pressure water so more efficient.
Outboards have tiny props so prop walk minimal.
Add in a big pitch and it’s like a paddle wheel.
