NickC
£9.95 per litre![]()
I guess say 10 ltrs would be enough to run the engine in a bucket. So how many litres of Rydlyme would I need for that, it is used neat or mixed with water?
B&Q powder descaler. Works for me, less than £5 for two sachets. Find it in the plumbing section.
Vinegar is a dilute solution ( about 5%) of a fairly weak acid, acetic acid, pKa = 4.76.
Safe? certainly. Safest? possibly.
Most effective? Hardly! 1 litre of 5% acetic acid will dissolve , in theory, only 41.7 g of calcium carbonate scale and it will do so rather slowly compared with an equivalent concentration of a strong acid such as hydrochloric acid.
Cheapest ? Possibly even at around 50p per pint from supermarket
Well whatever it is I mix one sachet with about 1/2 litre boiling water so the last just dissolves. Doesn't hurt the skin like hydrochloric, and two soaks shifts most stuff, and the gas released isn't too pungent either. Also seems to ignore most metals, and doesn't dezincify brass (turn it from yellow to red). I do remove any zinc anodes first.So is acetic acid available in powder form that can be mixed up to a stronger concentration? If so what quantity should I use per litre of water.
Citric acid is cheap to get in bulk.
A lone voice in the wilderness! - I agree with you though - orthophosphoric acid is the doggies do-das for descaling inboards and outboards.Yes. Hydrochloric acid is the same as in your stomach, so sailors often put it in the sea.
It might be worth using Scale-X from http://www.taylormclure.co.uk/pages/more_information__scalex_156938.cfm
It removes scale and treats rust: it is Phosphoric Acid, as used in rust converters.
Hence safer for use on Aluminium jacketed waterways?I have seen phosphoric acid suggested for descaling. It has a pKa1of 2.15 so is in fact a weaker acid than sulphamic acid.
I use around 4% and recirculate the coolant until hot then keep going until max temp is reached.Hmmm - our company stocks this for another purpose. I can obtain it at wholesale cost.
At what concentration would you use it?
A lot of the supermarket descalers are sulphamic acid based, I think the one that lives in our bathroom is called vical or something like that.Hi John,
Interesting but I am based in the UK so posting it from NZ might unfortunately cost more than buying it from a supplier in the UK. Looking at the recommended concentration for Fernox DS-3 which is Sulphamic acid based it seems 100mg per litre is recommended.
Nick
4%~5%Hmmm - our company stocks this for another purpose. I can obtain it at wholesale cost.
