Whopper
Opinions on best power to weight portable outboards currently on the market greatly appreciated. We recently purchased a new Talamex silverline 2.7m aluminium rib as a tender to be fitted with a Mariner 8hp two stroke off the old dingy. Very happy with the rib so far and it feels well put together to me. Unfortunately the engine has seen better days and is most likely beyond economic repair with corroded carbs and tired water pump for a start. I'm undecided whether to go for a lighter 6hp or heavier 10hp. From what I can tell 8hp outboards are generally the same engine/unit as most manufacturers use in their 10hps (I think) so in that case might aswell go for the higher output for the same weight.
In 6hp range the 2016 Honda looks quite nice. Would this be enough to get a 2.7m <45kg rib on the plane with one person or better still with two? If it does that would be great as it's keeps the total weight down for hanging on davitts. If not I'll probably steer towards a 10hp and I think the Yamaha looks to be one of the better ones and seems to most lightweight 10hp.
I don't think this is a try before you buy situation so any insights are appreciated!
