KAL
Outboard cooling water problem - now solved!
My 1999 Yam 8hp 4 stroke developed an intermittent problem towards the end of last season, where the cooling water flow seemed to be restricted. It was still cooling the engine, but flowing much more slowly than usual. I put this down to a combination of, possibly, a bit of mud in the circuit and the need for a new impeller.
When I got it home and winterised it, the flow was re-established strongly, so I congratulated myself on shifting the mud/grit/cr4p that might have been causing the problem and resolved to change the impeller before launch.
Today, I serviced the engine and changed the impeller but, to my dismay, the cooling water flow, after being strong at first, then became feeble and stopped.
I have checked that all the channels are free, but there's almost nothing coming up from the lower unit.
The water pump looked fine when I changed the impeller.
Does anyone have any idea where to turn next? I plan to get the lower unit off again tomorrow morning and check that the channels down there are all clear, but I can't think what else to do apart from replacing the water pump unit, but that's expensive and I'm not sure that's the problem or how to diagnose it if it is.
Any ideas folks?
Any ideas folks?
