LONG_KEELER
Mariner 6hp 2008 4 stroke OR
I've just changed the impeller and the pee hole water flow is magnificent. The engine starts ok with the propeller power running ok tied to the pontoon.
The engine sounds like it's running on land without a water flow . I'm not quite sure if the propeller wake is what it should be.
Is there a way that I can test if the exhaust is running ok through the propeller ?
Could I have done some damage putting the leg back . I had quite a struggle ?
Any ideas welcome.
TIA
Any ideas welcome.
TIA
