Johnson 4 Seahorse twin ....
Took to service people and they didn't want to do it ..... yeh - they turned down work !!
Anyway ... I've heard that fluid can be injected into the water outlet to 'back-clean' the passages ..... the notes I read talked of inverting the engine and injecting in .... leaving it for a while ... then standing on side, then upright ..... letting it drain out the intake .....
Sounds too good to be true and also I am concerned about the leg oil when its inverted ......
C'mon panel - someone must have the answer to my J4 woes !!! If it is possible - what fluid to use and method ....
