winsbury
We currently have a bulletproof and reliable but old 8hp Mariner Sailmate 2 stroke in well as our main engine (approx 2 ton bilge keel 23ft loa sailboat .) Problem is that its noisy and smelly and almost always sets the fire alarm off and makes me feel a bit sick after a while so is far from ideal for a long run but it drives the boat well even against the strong currents around Langstone at 5.5 - 6 knts at full throttle.
I'm therefore thinking of changing to something cleaner and quieter but dont want anything overly heavy that will affect boats balance ( 6 - 8 hp I believe is the designers recommended size for our boat.) I'm thinking a 8 or 9.9 hp four stroke Mercury / Mariner but have some questions for the more experienced and less sales commission motivated panel before parting with around two grand:
1. What is the difference between Sailmate / high thrust and the standard engines/props .
2. what on earth is the difference between the 8 and 9.9hp engines - on paper they are the exact same spec and weight except for power rating... do the 9.9s have a larger prop so would rev lower for the same thrust as a 8hp ?
3. will a 4 stroke be 'much' quieter than the 2 stroke
4. will the fumes be any less potent
5. The existing 8hp engine rating is presumably in old money ( power at prop versus crank or something like that ) so how does that compare with power ratings on new engines.
6. How does one select the correct HP for any given boat - is there a formula ?
Any or all queries answered would be much appreciated.
