Wandering Star
Thinking of DIY treatment of an osmosis riddled hull. The surveyor mentioned he used a Tramex Skipper meter to measure the moisture content of the hull and the readings were “off the scale”. I know of another meter a Sovereign make which is used by surveyors too. as the hull dries out, I’d like to take regular hull moisture readings myself to monitor the drop until it stops dropping at which point I understand it won’t drop further and I can consider the hull is as dry as it ever will be.
But, the Tramex Skipper costs a whopping £370 or so and I wondered if there were other meters I could use. I see Chinese meters for measuring the moisture in wood or concrete costing £20 or so, would they do the job? I’m not looking for accuate readings, I’m only interested in watching a drop in relative readings taken over several days. Anyone able to give advice?
