jrussill
The Colvic Countess 28 hull will be built like a tank compared to the lighter Virgo Voyager![]()
Yes she certainly has that feel to her!
Only wooden boats dry out ashore.
GRP boats are just not getting any wetter when they are ashore.
GRP with an epoxy coat is as good as waterproof and won't get wet anyway.
The less dense the water the more likely it is to pass through the gelcoat. Therefore, as has been said, fresh is less dense that salt and warm is less dense than cold. A warm lake therefore the worst.
If water has passed through the gelcoat ("osmosis") it desolves into poorly mixed parts of the laminate, becomes more dense and will not come back out again. Bubbles are caused when the reaction builds up pressure and that's what we call osmosis - actually osmosis is the water going in and any boat without epoxy will have it to a degree.
The only way to dry a GRP hull is to peel off the gelcoat and jetwash every day until it is dry - you are not removing water to dry it, that evaporates in hours, you are removing the more dense substance. OK not the only way you can speed it up with steam, vacuum etc but jetwashing will do it after a few weeks.
Then replace the gelcoat with epoxy.
Frankly, a lot of BS served here, but it is not all wrong.
A grp laminator told me that he thought most blisters were caused by air bubbles trapped between the gel coat and the laminate during lay up.
Its actually difficult to avoid because the gel coat is applied with a brush and leaves brush marks. The first laminate bridges across the marks leaving small bubbles.
When the temperature changes the pressure in the bubble is less than the outside and moisture permeates through the gelcoat into the bubble. When it warms up the air is again expelled leaving moisture in the void. This carries on till the bubble contains only water then the warmth causes the water to hydraulically expand enlarging the bubble and distorting the surface.
This continues with temperature change till the gelcoat blisters can be seen.
When stripping off the gelcoat you can see the original bubble under the first coat of laminate.
So usually the problem is only in the gelcoat to laminate boundary and not a failure of the laminate at all and the gelcoat is only a cosmetic layer so these blisters are not of structural significance.
Applying a layer of epoxy works because it is far less permeable than the gelcoats used.
Slight thread drift but I often notice hulls with no blisters have rudders covered in blisters.Anyone have any theories why?
For higher quality, Bavaria spray the gelcoat into the mould, which ensures a smooth surface on which to start laminating. Interesting video of the process here - gelcoat spray is at around 2:40 in the video.
Bavaria gelcoat is as good as it gets. Better than a rassey by miles.
Not all BS eh? Thanks for that. Tell me specifically what, in my simplified expaination, was actually wrong.
snipped - Whether GRP boats does not dry at all or just dries slowly is debatable. I have no actual data on this.
Boat (not mine) lifted out on a nice dry day late last autumn, after 2 years in the water. A few days later (again dry and sunny) the hull was showing typically 50-60 on the 01-100 scale of a Tramex moisture meter on GRP setting.
Last month checked again after a winter ashore, moisture meter readings now typically 35-50.
My feeling is that wintering ashore clearly reduces time in water, and hence absorption, but also some drying does take place in a UK winter even through antifouling.
