Eero Gaffney
New Member
The past few days I have taken my polyester boat (from the 70s) out of the water and started prepping it for primer and antifouling. We first scraped away all of the lose layers of paint with triangle scrapers and then sanded down the rest with 80 and 60 grit. Initially I had noticed 2 of 3 osmosis Blisters around the size of a penny. Yesterday though after further sanding I found many more small ones (around 50) pushing up through the gel coat. I think foolishly I decided to start popping them thinking I'd fill them in with epoxy. I realize now that this does not address the root of the problem which is a general osmosis of the polyester. Since popping them I've dug around them expanding the area exposed to allow for better drying out. I did this mostly where the gel coat came off easily and showed wetness underneath. Others which seemed better adhered to the polyester I left relatively small. I did not on any places dig into the layers of polyester themselves as they all seemed dry within an hour or two. I then (again foolishly) started sanding the polyester and edges before cleaning them. I then bought some fiberglass prep cleaner and wiped the popped blisters down. After I re-sanded some more and then gave them another wipe. Some of the colour from previous sanding of the old antifouling and primer coats seems to have seeped in though (as seen in photos). I then gave everything a hose down. My plan is to let the blisters dry out for two days and then prep the surface with acetone and fill with epoxy resin thickened with colloidal silica. I am wondering whether anybody has any advice or suggestions for this process, if it seems like I have prepped properly (I fear not) and ultimately, whether the epoxy will adhere properly to the fiberglass and surrounding gel coat. If not, what can I do to make sure that it does. Thanks a lot for your help!
