If you enlarge the photo and look at the bottom RH corner you will have an idea of the number of logs you find floating around in the water. You definitely want a steel boat around here.
John
[/ QUOTE ]...err, like a big ferry?
If you look at photo 5, it is clear that at least one piling of the marina is done for. The infrastructure damage might be as much as any boats destroyed.
Agree with you there Tome. It seems that a refit of sorts has been done recently so, if the captain's hung out to dry, there should be a few dockyard mateys pegged out on the same line alongside him.
