gravygraham
We've had an overheat message appear in the lcd window in tacho (no buzzers sounding though), so I checked the engine temp and it read 95 degrees. We throttled back and after just a minute or so the temp dropped back to it's usual 85 degrees. All was ok for a while but when we went WOT again the issue recurred. The strainer basket's clear, we're full of antifreeze mix coolant, the impeller is fine (we put a new one in anyway). What else can I check? I suspect it's a 'real' problem, rather than a 'virtual' problem, e.g. faulty sensors.
Any advice gratefully received.
