Concerto
All this talk of inboards and outboards misses the point. Any engine on a yacht is called an auxiliary, as your primary source of motive power is your sails. On the other hand you could follow the French on many of their small yachts, they have no engine - so nothing to go wrong. They just use a long sweep (stored up the backstay) and scull the boat. Small yachts that you are looking at are easy to get moving and very easy to steer in close quarters. OK, an engine just makes it a bit easier but does have all the associated engine manias you dream of. In over half a century of sailing I have found the most likely problem is running out of fuel. Other problems do happen very occasionally. Wansworth you should be looking for solutions to your not having a boat rather than looking for problems.The whole engine thing is a mania……will itstart if it’s stopped……once running will it stop…….it happened steaming into Littlehampton just on the start of thr ebb and the engine stopped ,managed to get a rope round the bulastrade of the pier…….butwhy did it stop?……sort of mild panic!…….I don’t recall now what I did nothing involving spanners but it started again .
