temptress
If you connect the solar panel to a variable load together with a voltmeter and an ammeter
Record volts and amps as the load is varied , multiply volts by amps to get the power in watts and plot a graph of power against volts you will get a curve which rises to a maximum and then falls again.
The peak is the maximum power point at which an MPPT controller tries to control the solar panel. the corresponding volts is VMP
Thanks finally see what's happening there but still need to know if multiple Mppt controllers are needed?
