sarabande
The insurance company says it's about time I renewed the standing rigging (agreed). I have a very heavy duty in-mast mainsail furling system, and a roller furler genoa as well.
I hanker for a sail reduction process that doesn't rely on gears and swivels hidden deep inside the mast, so....
Do I ditch the 18 yr old mast and furling system, and go for two masts (ketch rig) with "normal" slab reefing on the main, and a cutter rig for the foresails, or a newer version of the roller genoa. It looks as if the main and both genoas are in pretty reasonable shape, but reliability and resilience are significant drivers in my mind. (It would also be nice to reduce weight aloft a bit, and have the ability to raise and lower masts independent of shore-based facilities)
Present boat config is a long-keel, motor sailer; and future use is long-term cruising, inshore waters, European canals, with a bit of cross-chanel and round France to Spain possibly. Crew is decrepit desk-driver, assisted by inexperienced SWMBO.
The present system works OK, but I suspect is nearing the end of its reliable life, and I am prepared to make big changes to get the boat "right" for the next 10 years, with easy sail handling and safe mast and rigging as the priority. I am not expecting dramatic improvement tot he sailing quality, which is at best, described as "sedate" !
