Nick_H
I suspect I have an issue with my port engine, D-12 715hp, 2004. Symptoms are:
1. On a 5 hour cruise at 20-22 knots I'm pretty sure I could see a feint witness of black smoke from the port exhaust that couldn't be seen on the stbd side
2. There was a sooty deposit on the transom that I haven't previously suffered, which was biased towards the port side
3. Fuel gauges were equal when we left, port tank showed 1/8 lower than stbd on arrival, although the fuel gauges are a bit temperamental and sometimes move 1/8 of a tank in a single step, so I can't be sure on this.
4. Port engine tacho rises a little more slowly when both throttles pushed to the stops and the turbos kick in
Temps and oil pressures are normal, air filters new and clean. I didn't think to open the throttles up to see what rpm each engine would reach at WOT.
Any thoughts on what I should be checking, or tests I can run to try and identify the issue?
