Jamesuk
Hi,
We had the SSB replaced but now we have one of our midship grounding plates looking like it probably fizzled when the SSB was being tested.
Set up:
Midship below nav station we have two circular grounding plates which are about 14cm in diameter. Looking at both, one seems to be connected to the inverter, the other has a copper strip leading up from it to a bolt which has all the electronics in the vicinity grounded to it Including a large wire that disappears off to another location. This on the hull is the heavily corroded one.
At the back of the boat we have two grounding plates fitted for the SSB 9 years ago around 20cm long each which look as they have always looked.
At the stern we have an anode on the prop that is worn away more than I have ever seen it on the propeller (Gori) the other anode above it looks fine but with the bar appearing to be rusty (could just be air that did that)
I tried a continuity test between the anodes/shaft and damaged grounding plate and I get no continuity. I am now inside the boat attempting to do the same but access is pretty awful.
Any thoughts or perhaps better a local sparky expert who can come and visit the boat would be much appreciated (Southampton)
Cheers
James
Set up:
Cheers
James
