owen-cox
That is simply not correct. It is perfectly possible to retrofit R134a. R134a uses PAG oil, not ester. R12 mineral oil can be replaced with POE oil (which is an ester oil) and will mix with small amounts of mineral oil. I've done several retrofits and every single one has worked perfectly well.
A small amount of polyol oil with dye in it finds leaks easily.
I worked with several of the large marine refrigeration companies (dometic, condaria, isoltherm, frigoboat etc) as an agent and I was advised by all as well as OEM compressor manufacturers manuals not to mix any amount of mineral and polyolester oils together. R134a will not mix with mineral oil and will not allow the oil to move around the system correctly. How could you be sure you got all the oil out of the compressor?
I too have done replacements of refrigerants but as the outcome is not 100% certain I would not recommend it on a system that has been obsolete for 20 years.
