Onan genset lights
bluetooth
30 Dec 2015
Poole
Evening All.
My onan genset works fine but the controller in saloon has both green and yellow lights lit when working. The lights on the genset in ER only show green light on.
Anyone had similar issue?
Only the green light should be on, try unplugging the remote panel and plug it in directly on the generator to see if it is the switch or remote wiring harness that is the issue.
Yes you are correct if it is a EQ Diesel generator, but the yellow light should go out when the green one comes on.
Indeed the yellow is prime and should go out once cranked with green light on.
Engineer thinks might be a circuit board issue as the yellow light on the control panel on the genset also stays on but to a very dim level.
The genset is working fine so will investigate further.
does it start the same , only some pre heater light stay on if the heater plug is faulty.
Yep better than ever after good servicing and maintenance in my care over last 5 years. Prior to that wasnt well looked after. The yellow light staying on only started end of last season.
