corkonian1
My ancient manual toilet on the boat has a valve with two positions, open and closed.If the bowl fills with water when valve is in the open position (pump in ) to clear the bowl I close the valve and pump out the bowl.However I seem to be forcing something as the pump handle requires much more force in this case.I have dismantled the pump to clear salt corrosion. The pump valves are rubber flaps weighted with lead and the in/out valve is a rubber plug which pivots. Modern toilets have pump in and pump out positions. Am i using the toilet correctly?
I cannot see a makers identification.
