old standing rigging
bluerm166
29 Sep 2009
What to do (ethically) with complete standing s/s rigging set in 5 and 6mm 1/19 10 yrs old but without apparent defects ?
Replaced now only to suit maintenance cycle convenience .
Ideas ?
C40FB318-6334-47C3-8B1D-3157210884E3.jpgMight not be of much help but I bought a few dozen ss eyes and hooks and used my old standing rigging as a trellis for my house. This was done last year and throughout the summer was home to Clematis, climbing roses and Wisteria etc. Earned loads of brownie points from SWMBO and i expect it to last forever.
The week before Christmas I used one of my old mizzen shrouds to help brace an acoustic positioning beacon in position underneath a chartered angling boat. I’ll be doing the same thing again tomorrow.
I realise this is a somewhat niche application :p
I've used a length to brace a large folding saw-horse - another niche application. Trellis is good - or a washing line.
As said the uses are endless. I use bits of copper tubing as ferule for swaging a loop in the end after cutting. Not very strong but useful for trellis etc. But to get rid of it, sell it to scrap metal dealer. olewill
Give it to someone with a smaller boat. As mentioned in the previous post 'the uses are endless' ooops... make that 'the ends are useless'... however.....
When did you last see a rigging wire that parted in the middle?? Nope - they fail at the terminations... either that or the T-balls or bottlescrews themselves fail.
With the ends trimmed the wire is good for some time yet.... esp if the recipient only sails locally... but maybe not my choice for a non stop circumnavigation....
I suggested as much to my rigger once... he told me to foxtrot oscar as wire sales were where the profit was in the business..... he did not contradict me.
I would imagine you would have to appologise to Malabarista for pulling his guttering down :rolleyes:
This was indeed the case when a particularly ‘gifted’ teenager did the chain pull trick. It is now screwed into the green oak beam behind the fascia ( which may or may not be attached to the plumbing)
From a smaller boat I used the old wire for supporting raspberry canes, cut shorter, a loop made in the end, fixed with a ss clamp and then lashed to the post. Not quite sure what I'll do with the much larger 7mm wire from my current boat in the spring when it's renewed - a washing line sounds good, at least it'll never need replacing in my lifetime!
Raspberry supports is a good one. Long ago, the previous owner of our house – who worked for a power company – had recycled as clothes line pulley sheaves a couple of the brown porcelain insulators used to suspend power lines!
