Steve_N
I'm in the process of replacing the output shaft oil seal on my 30 year old VP MS3B reverse gear.
The original part is obsolete but is a metal single lip nitrile oil seal 60mmx85mmx8mm.
I'm told that the part that Volvo now supply is a standard rubber-coated metric seal of those dimensions, so I'm planning to source one locally.
The shaft sleeve (£275..) on which the seal runs is in good condition under the seal itself but is coroded outboard of the track of the seal - so it's imperative that the lip of the new seal runs on the good part.
Now to the question.
The 60x85 seals are also available in 6mm: if I were to fit a 6mm seal in place of the 8mm seal would you expect that to move the lip position inward further onto the clean area of the sleeve or would there likely be no difference?
My other options are to get a sleeve made by an engineering shop or to get the existing one turned down by 2mm as 58x85x8 seals do seem to exist too.
Probably unanswerable I appreciate, but thanks in advance for any thoughts..
