royaldo
Hi,
I recently bought a boat with two TAMD71A engines with about 1360 hours. Before purchase, I had the boat surveyed by a local survey company with no remarks to the engines. Afterwards, when the deal was done I discovered the following:
Coldstart:
RPM ~475 (idle - appears to be set low)
Temperature ~30-40 C
Oilpressure ~62 PSI
(same for port and starboard)
Hot engines after sailing for 45 minutes or so:
Port:
RPM ~2000
Temperature ~100 C (hot but does not rise further)
Oilpressure ~50 PSI
Transmission ~230 PSI
Starboard:
RPM ~1850
Temperature ~95 C
Oilpressure ~50 PSI
Transmission ~275 PSI
With hot engines the oil pressure is around 30 PSI on both engines on idle. Surveyer reported that temperature was 93 C on both engines, tested with infrared gauge, when he had the boat on sea-trial. All my measurements is taken from the electric gauges which is as old as the engines...
As I recall, the Volvo manuals specify a minimum oil pressure at idle at about 30 PSI and about 65 PSI under operating conditions on the engines and about min. 295 PSI on the transmissions.
I'm starting with changing all oils and filters, checking the cooling system and having the pressure numbers checked with manual gauges. Other relevant items to check?
Am I being overly concerned about these numbers?
Coldstart:
Oilpressure ~62 PSI
Port:
RPM ~2000
Oilpressure ~50 PSI
Starboard:
RPM ~1850
Temperature ~95 C
Oilpressure ~50 PSI
