oldgit
Two thoughts:
1. Swap the engine sensors and see what happens (and/or swap the gauges too).
2. Check that the low oil pressure reading is in fact correct; I bought a professional pressure testing kit, complete with a range of connectors for a few quid on the internet, that showed the sender/gauge was showing the actual pressure correctly. However, that low reading was deemed acceptable by Yanmar for idling. When I had Yanmar 4JH2-UTE engines, I found the following quotation in a Yanmar manual:
Engine speed 3000 rpm ---- 4.0-5.5 kgf/cm^2
Engine speed 800 rpm ---- 0.6 kgf/cm^2 (I suspect this is a minimum).
Another note I have from days of owning those engines:
Yanmar type oil pressure sender PN:119773-91501. This sender has a
pressure range of 0-8 bar with a resistance range of 83-12 ohms
Thanks for those observations.
Having only had VP engines with their OP gauges marked with PSI, was disconcerting to see the needle on the Yanmar gauge so close to the "Red" section of the dial at idle.
It would appear this has been the cause of much consternation to many other boaters with Yanmar engines over many years. In common with all the other postings on the net on this subject , the separate alarm had not been activated.
The usual path of action seems to be, check the oil pressure with a test unit and if within acceptable limits either ignore the gauge reading or buy a genuine replacement Yanmar sender which has solved the problem.
Some have simply changed the gauge and sender( on both engines if twin set up.)
Will probably go down the check pressure with independant tester and leave it at that until can summon up enough enthusiasm to investigate further.
