stav
Having done some searching I still have some nigelling questions in my mind and having come to the conclusion I will keep her and not get something smaller just for me I wish to get a handle on the situation with my engine.
It is the original engine from 1977 but was rebuilt in 1996 but I have no idea what was done. It is a nice colour and has an oil cooler. The hours gauge reads 3600 hrs (ish).
It starts quite well turning over only a couple of times before starting. When the enngine is cold the oil pressure is 40psi and steady whatever rpm. As the engine reaches temp at 1800rpm and above, I normally run at 2200 rpm, the oil pressure shows 40psi, as I throttle back it steadily drops so at 1500rpm has 30-35psi and at then at tick over drops to minimal and hardily readable 5psi?. In the manual it says idling pressure can be low but I can not remember if it was 1 bar or 1psi...
The oil is carlube 15w40 mineral and has been given three oil changes in the last year as I suspect it might not have had much use for three or four years and not many oil changes.
So can I live with this oil pressure? Could some pressure relief valve be operating too soon? wear in the oil pump? If I can just stop feeling anxious about it will the enigine contiune for 5 or 10 years or will it suddenly start knocking?
What jobs could I build in to the winter schedule to improve things?
As always thank you in advance.
