Oil pressure gauge query?
jamie N
20 Dec 2012
Fortrose
On start up, the gauge reads 6-7 bars or so. As it heats up, the pressure decreases, until it shows 1 to 0 bars.
The engine temp remains the same with the cooling system not having to work any harder (it's easy to monitor on this engine), and there's no smoke, nor does the engine use any oil, or have any symptoms of anything being awry such as 'smelly oil' or loss of performance.
The gauge wasn't fitted as a unit with the sender, it was from the back of my garage as a leftover from a different project, which on 'googling' doesn't guarantee great accuracy. The engine's run many hours since a major rebuild, and clean of the cooling passages in the block and head, and hasn't ever been any different since reassembly.
It's probable that with winter being here, I'll replace them as a pair, but has anyone else experienced this?
I have experienced something very similar. On my BMC 2.5 engine, no oil pressure gauge was fitted. I installed one, with very similar results to yours. The pressure switch never activated but the gauge showed 0 psi when hot. I assumed the transducer was faulty. Boat sold now.
Hi. I’d firstly suspect the gauge is questionable. 7bar I think is over 100 psi. That would be ridiculous oil pressure, even stone cold. What engine is this and at what rpm are you at when like this ?
The symptoms are throughout the rev range, and very consistent. If I notice that the pressure is low at start-up, then I'll be very concerned.
Given the time of the season, I'll be able to change the sender and the gauge for a 'matched pair'.
The engine's a Ruggerini RM90, which is in no way remarkable except for a couple of bits of being Italian, if you see what I mean!
I'd replace the set.
First find your engine's oil pressure as specified by the manufacturer. Might look something like this (BMC 1500), probably even stating temperatures:
Check the conversion to other values e.g. psi, bar etc.
Then buy a sensor & gauge to display the relevant range - plus some on top to prevent the pointer from max out when cold.
Budget chinese matched pair of sender and gauge on Ebay from around £10.00- £15.00 .
Works pefectly well on a marine diesel.
You can spent loads more for something of better quality ? with a known name printed on the dial.
Need to ensure the male thread on the new sender unit matches the female on your engine block .
Loads of different threads both imperial and metric, need to get it right , or you will spend more on adaptors than on the new gauge and sender.
2" 52mm Digital LED Oil Press Pressure Electric Gauge 1/8 NPT Sensor Sender 12V | eBay
Thanks for that, that was the way that I've been looking.
Just as an aside for your post and the eBay ad:
Postage:
Doesn't post to Scottish Highlands | See detailsfor postage
Located in: Welwyn Hatfield District (B), United Kingdom
Back in the CA days, that'd be a worthy conversation also.....?
