Oil in exhaust when underway
Nickm9921
New Member
1 Aug 2021
My GK 24 has a Volvo MD5a and when underway at high revs the exhaust blows out an oil slick and black smoke. Note this only happens when underway and not when alongside even at full revs. Does anyone care to enlighten me?
thanks
[QUOTE="Nickm9921, post: 7752880, member: 1876
[/QUOTE]
Black smoke and a slick point to overfuelling. A number of possibilities, fouled prop, blocked exhaust elbow , possibly a fuel system issue.
Are you in gear or in neutral when alongside? You would not expect this effect in neutral.
My Perkins when full revs has similar and that is because it is definitely getting too much diesel when loaded (in gear)
Black Smoke is the diesel that is burnt (too much). Slick is from the unburnt diesel.
You may be able to reduce it a touch by having injectors cleaned / calibrated - but doubt it will make much difference.
[/QUOTE]
It doesn’t happen even when in gear alongside
[/QUOTE]
How clean is the hull?
If a diesel engine cannot reach the revs that the fuel pump expects due to overloading it will produce black smoke and unburnt fuel in the exhaust. If you back off a bit does the smoke clear?
[/QUOTE]
have a read here.......https://www.capitalremanexchange.com/causes-of-diesel-engine-smoke-by-color/
Make sure your cold start lever and plunger on the engine are returning after the engine has started. Even though the pull knob is pushed fully home it's possible the plunger can stick on the engine.
