lw395
Interesting - Yanmar state that under no circumstances should synthetic oils be used as these can seriously damage the engine.
Only mineral oils should be used in non turbocharged engines.
Where do they say that, currently?
It's hard to believe that running at constant revs would destroy an engine. After all, most diesel generators do just that.
I would change the oil and filter every year however much the engine is used, it doesn't cost much and better safe than sorry. Long distance sailing we changed them every 100 hours as the manual required.
Wow! some strange ideas!The older the engine the more frequent oil changes. The biggest reason for frequent oil changes on older engines (mine is a 40plus year old MD11C volvo) is contamination by fuel passing through and diluting the oil. I do between 40 and 100 hours motoring per season and I change the oil and filter every year; If i do less than say 30 hours, I will not change it; there is no fixed rule in my opinion. Engines that use fresh water for cooling, may have a huge problem with glycol finding its way to the oil and creating acid and increasing the oil viscosity, but, this is a different issue. Oil type and quality is even more important than change frequency. I use modern fully Synthetic oils of low viscosity and high lubrication; which is an anathema for some.
S
We need to change the oil after the specific period of time?
If yes then can anyone please tell me the interval after which oil must be changed.
