Graham_Wright
The sump drain pump is totally inaccessible and there appears no way to make an access.
The dip stick tube bore is around 7mm diameter. I will try to suck through that but, with a Ø5 bore in the suction pipe, it will take forever and will doubtless be blocked by sludge.
Has anyone found the courage to create a new access plug with the engine in situ? The sump metal will presumably be too thin to allow a tapped hole although maybe there is an oval widget which would make it possible.
