markc
Hi all
After 2 years without a boat, the arrival of a little one, I have now put an offer on a boat. I have the main survery due next week, but I have seen a survey from less than 12 months ago and all looked fine, so I don't think I'll get any surprises.
However, I took oil samples last week and have just had the results back - both samples were showing very high levels of iron (suggested as crank wear) and high levels of copper (sugested as bearing wear) - everything else was minimal. So, my question is, to those who have experience in these matters, should I be worried? The engines are Mercruiser 7.3l D-tronic (300hp) and have done approx 320 hours each, so seem to have run too few hours to be showing crank wear... on both units. Also, both engines have recently been removed from the boat to have new exhaust risers, and from what I have heard, the engines have not been run much over the past year. Both engines fire up well, run smoothly and have good oil pressure.
Could the iron have come from oxidation in the bores if the engine has not been run often, or maybe from the recent exhaust riser work?
Any thoughts very much appreciated!
Oh, and here are the full reports...
Port
SYMPTOMS: Note levels of: Copper 194ppm,Iron 113ppm and Silicon 36ppm
DIAGNOSIS: Evidence of component wear, Some crankshaft wear
ACTION: Please investigate cause
Date Sampled
Date Received 12/07/2010
Date Tested 14/07/2010
Oil Life (hrs)
STATUS CRITICAL
PHYSICAL PROPERTIES
Viscosity @ 40°C cSt 88.6
Water Content %wt 0.0
Total Insoluble Matter %wt 0.2
SPECTROCHEMICAL ANALYSIS
Iron ppm 113 ** Evidence of crankshaft wear
Chromium ppm 5
Aluminium ppm 12
Molybdenum ppm 108
Copper ppm 194 ** Copper pipework/bearings wear
Lead ppm 9
Tin ppm 0
Nickel ppm 4
Silicon ppm 36 ** Possible dirt from filter/trunking
Sodium ppm 26
Boron ppm 33
Vanadium ppm 0
Calcium ppm 3147
Phosphorus ppm 951
Zinc ppm 1268
Magnesium ppm 61
Barium ppm 0
S'BOARD
SYMPTOMS: Note levels of: Copper 54ppm,Iron 93ppm and Silicon 36ppm
DIAGNOSIS: Evidence of some component wear.
Date Sampled
Oil Life (hrs)
STATUS CRITICAL
PHYSICAL PROPERTIES
Viscosity @ 40°C cSt 78.3
Total InsolubleMatter %wt 0.3
Iron ppm 93 ** Evidence of some crankshaft wear
Chromium ppm 5
Aluminium ppm 9
Molybdenum ppm 112
Copper ppm 54 **
Lead ppm 4
Tin ppm 0
Nickel ppm 3
Silicon ppm 37 ** Possible dirt from filter/trunking
Sodium ppm 8
Boron ppm 28
Vanadium ppm 0
Calcium ppm 3075
Phosphorus ppm 1054
Zinc ppm 1240
Magnesium ppm 81
Barium ppm 0
Port
Date Sampled
Oil Life (hrs)
STATUS CRITICAL
PHYSICAL PROPERTIES
Chromium ppm 5
Aluminium ppm 12
Molybdenum ppm 108
Lead ppm 9
Tin ppm 0
Nickel ppm 4
Sodium ppm 26
Boron ppm 33
Vanadium ppm 0
Calcium ppm 3147
Phosphorus ppm 951
Zinc ppm 1268
Magnesium ppm 61
Barium ppm 0
S'BOARD
Date Sampled
Oil Life (hrs)
STATUS CRITICAL
PHYSICAL PROPERTIES
Chromium ppm 5
Aluminium ppm 9
Molybdenum ppm 112
Copper ppm 54 **
Lead ppm 4
Tin ppm 0
Nickel ppm 3
Sodium ppm 8
Boron ppm 28
Vanadium ppm 0
Calcium ppm 3075
Phosphorus ppm 1054
Zinc ppm 1240
Magnesium ppm 81
Barium ppm 0
