craigsmith
Re: another anchor debate
Yawing shifts the angle of pull laterally by up to 60 degrees on some vessels. CQR hinges deal quite well with that problem. Rigid shank anchors shift their angle more, and have a bigger risk of tripping and needing to re-set.
[/ QUOTE ]This is incorrect. Sufficient force to pull a rigid anchor around or trip it out will also pull the CQR straight (do you really think it sustains large forces with its shank on an angle?). Weak forces which do not pull the CQR's fluke straight will not trouble a rigid anchor.
Of course if an articulated shank was advantageous, every anchor since the CQR would have one, but in fact all have avoided it.
Pitching is most commonly met in the Med, mooring bows or stern to, or with a line ashore, when the wind suddenly blows from an embarrasing direction. But the lateral angle of pull stays constant. Rigid shank anchors come into their own in this situation.
[/ QUOTE ]Pitching does not really affect the anchor in the sense of changing the angle of pull, unless you are using extremely short scope. Shanks on anchors obviously require more strength in the vertical dimension than in the lateral dimension, but this does not affect the idea of articulation.
