boatone
Been a bit of banter with rumtigger re floatswitches but actually got me into some serious thinking re this whole issue.
Bilge pumps can be activated automatically or manually for two main reasons....
1. Routine removal of minor water....sterntube drip etc
2. In anger cos exceptional inflow of water in an emergency
If a float switch is fitted they will operate automatically and in situation 1 cut off again. Howver in situation 2 the bilge pump may be unable to cope with the inflow and the boat will be at risk of sinking. In both cases without some sort of additional alarm you may be unaware that the bilge pump has actually cut in. If the boat is in the marina and connected to shore power the pump may operate indefinitely but on battery power will eventually run down the batteries and stop.
Had a situation in my marina recently where by pure chance someone noticed a neighbours boat low in water and could hear pump running and just managed to avoid sinking due to ruptured skin fitting.
So heres an idea for debate.............
If boat usually dry inside and only reason float switch likely to trigger because of emergency water ingress then have audible alarm also connected to switch so goes off when pump triggered. If float switch triggers under normal circumstances then fit secondary float switch at higher level which will trigger audio alarm if water reaches that level. Either way audio alarm loud enough to attract attention whether on board or not.
Simple idea but I think it has merit.....What say you.....?
<hr width=100% size=1><A target="_blank" HREF=http://www.boatsontheweb.com/> Website, Photo Gallery, Chat Room, Burgees</A>
