Ardenfour
got my md1 back together after skimming the faces so I have to make quite a large adjustment to the valve clearances (the valves were 'dropped' according to the engineering co.) the valve end of the two rockers now sit angled upwards, whereas before they sat horizontal. I had to adjust them by about 5mm to close the clearance gap. is this a problem?
what is odd, the exhaust pushrod seems 'springy' - I adjust the clearance of the rocker, but I can press the pushrod end down about 3mm and it springs back up, as if there's a spring below the tappet.
any thoughts please?
