Birdseye
my boat has three batteries - one engine and two domestics, both the latter are identical but one a year older than the other.
using my sterling battery charger (excellent) all three float at slightly more than 13.4 volts. but after disconnecting the charger, one of the domestics drops to 12.62 within 36 hours whilst the other 2 drop to 12.72. At this point most people would say "internal leakeage" in the odd one out. but from thereon, the voltage drops slowly and in line with both the others. so it cant be a problem of charge leaking away through the sludge at the bottom of the battery.
even when fully charged, the SG of the odd battery isnt as high as the others. so could it simply be that this battery was fed a weaker acid / less acid when new?
over to the pbo experts?
<hr width=100% size=1>this post is a personal opinion, and you should not base your actions on it.
