oldbloke
You haven't missed much, horrible floppy things badly screwed together. The modern frp sandwich ones are a different matterI didn’t know that. Never sailed a grp Ent.
You are not wrong, but a blunt knife lifting you up is sl better than an axe blade pinning you down...But AFAIK the centreboard still came up above the thwart - and if down the handle at the top of the board would end any family life if ran aground. Hence why said fine for two rowing, one each side, but not one person other than a (current or future) eunuch.
The Caledonian canal (which he said he wants to do) is about 50NM long. That would be a heck of a row in a boat that is non ideal - I think given about 2/3rds of it is open loch, the OP is a sailor and there’s no suggestion to the contrary, I think we can assume he intends to sail it too.Surely fairly simple to cut the CB to shorter chord that did not extend above top of case. Or fabricate a new CB for rowing. OP has not said he wants to be able to sail the boat but we would presume a useful option. If with a cut down rig. ol'will
Surely the scenery is all around and there is no right or wrong way to be faciing?If the OP is going to row when he can't sail he will be facing the wrong way for enjoying the scenery,
That is more of an issue especially in the canalised sections - perhaps a mirror would help, or since an enterprise is commonly sailed with crew, perhaps he has an attentive crew?and he'll have to keep looking over his shoulder to avoid collisions.
I've noticed people rowing dinghies backwards around moorings to see where they are going. Not sure how much less efficient it is...If he prefers to use oars rather than my suggestion of sculling or using a yuloh, he could emulate the Venetian gondoliers and use a single oar on an outrigger (while serenading his crew and passers-by), or use two crossed oars like the Maltese dghajsa men.![]()
I inferred from the OP that he already owned the enterprise. Switching boat for better rowing probably makes no sense, as something else will be compromised instead. All boats are a compromise.Open to the forum for someone else doing the same - is there another budget sailing dinghy that would be capable of doing the trip that would be better for rowing? GP14 probably too heavy.
I'm sure that will row better but would that make up for the much poorer sailing?This would probably be about the ideal boat for the trip.
Boats for sale UK, boats for sale, used boat sales, Sailing Yachts For Sale 2000 Swampscott Dory - Apollo Duck
But as above, if the OP has the boat I think it will do fine.
Probably a good idea. As I said, and Ent with proper oars and rowlocks rows adequately for the few times you really need to row. The rest of the time it's a pretty good sailing boat, far faster than any good rowing boat with a tiny rig. Though the dory in the link earlier is pretty, but esentially a rowing boat with a sail that will do well downwind or on a reach.thanks for your consideration, I think i might have a go at making a sort of booster seat to go on the center thwart and sit over the centerboard as has been suggested.
I don't know - to be honest I don't know the detail of the route, the balance of sailing and rowing to be expected.I'm sure that will row better but would that make up for the much poorer sailing?
Sounds a plan. For doing the Caledonian Canal, worth working out how to also carry and fit a small two-stroke outboard - eg Mariner etc 2.5hp.thanks for your consideration, I think i might have a go at making a sort of booster seat to go on the center thwart and sit over the centerboard as has been suggested.
