thesaintlyone
So finally got all four nuts off of the Head Outlet Blakes Seacock which is being a bit crap to free up, probably due to well years of crap!!!
The Main Problem is the outside flange which I know on blakes is not connected to the internal but is rather a nut retainer. Which as I mentioned in another post was damaged see the picture below.
I spent today seeing how much of it was brittle and there wasn't a great deal of stength in the plate so I decided to remove as much of the backing plate as I could til i now only have the exposed heads in place.
So hear lies the problem as I understand from a former Longbow owner these nuts when originally fitted were put into wet epoxy or something when the seacocks were fitted into the holes so no ammount of tapping is going to just pop them out as they are embedded.
So I need to remove the embedded nuts???
Still free up the stuck Cone Which is not budging???
Tidy it all up???
Add a new backing plate and Bolts???
Or potentially replace the whole thing???
Now I know some of you suggested leaving the broken plate but I would rather know its all been sorted and replaced properly rather than relying on the brittle plate.
Thankfully this is the only seacock that has presented any problems and the other blakes are fine and I shall just simply replace the gate valves.
Tidy it all up???
