Matata
I have a mitsubishi pick up with 140k miles on it. it doesn't miss a beat. I bought it with no service history and i'm servicing it and learning lots at the same time. Im doing the rocker cover and tappets this winter and while I'm there I'm thinking of removing the injectors and having them cleaned/serviced. I get the impression they are a very old mechanical injector. The pressure from the fuel pump opens the injector type..not electronic or solenoid. Is it a good idea to do this? Is it reasonably easy to clean them ? If so, who would you recommend? Are there springs inside them that only allow the injector to open at a certain pressure.Would these guys check the spray pattern?Ta for the advice Nik
