john_morris_uk
I will not comment, I will not comment, I will not comment... Oh buggar it, yes I will. You get a hard point where the crimp stops and the wire starts too. If you solder properly you'll end up with the stress point properly supported by the heat shrink collar.
Hmm - I used to think the same and use the same logic and use exactly the same solder fittings!
Until someone pointed out that aircraft always use crimps as soldering has proved unreliable for the reasons I outlined. So I changed my mind and started using best quality marine crimp connections with a proper crimping tool.
Its 'possible' for crimping to produce a hard point - but much less likely when the crimp is done properly. Solder 'nearly always' produces a hard point as the solder wicks up the wire, and in some cables it can wick up several mm. If it doesn't wick up the wire, then there will still be a hard point at the connector which needs support.
In reality I still use those solder joints occasionally and for some applications, but I make sure that the heat shrink or tape supports the cable so that the hard join interface isn't stressed by vibration or movement. For example all my battery cables are soldered into large lugs which go onto battery clamps. The cable/lug intersection then gets wrapped in electricians or amalgamating tape etc.
