pandos
I want to renew the fuel system on my md21b.
I have a new lift pump en route and I am going to replace the cav filter holders with spin on Bosch type so there are less opportunities for air ingress.
I would also like to create a separate backup system with a 12v pump and separate filter directly into the injection pump.
To do so I obviously need to stop the fuel from one system passing out through the other.
In stead of taps/ manual valves I wonder could I simply insert non return valves..?
In theory if I have a problem with the main side I could just power up the secondary system and at worst bleed the injection pump and away I go... No need for fault tracing / repairs etc...
I hope a gauge (vacuum) in the main system might indicate a problem before engine stopped...
I think too high a vacuum could indicate a blocked filter and too low a vacuum could indicate ingress of air?
