skipper681
Is it a good idea? If so where would it go? In the bilge beside the pump or high up on the transom where the water exits?
Be aware that if you have a long pipe run between bilge and outlet (my boat as built has about 20 ft) any non-return valve will soon become not quite perfectly sealed and slowly leak the column of water back into the sump, re-triggering auto bilge pump. Repeats infinitely. I thus never leave the bilge pump switched on to auto.Is it a good idea? If so where would it go? In the bilge beside the pump or high up on the transom where the water exits?
You can pump through the manual pump but will lose the facility to run both together.
We have a Rule-Mate 1100 automatic, and it specifically advises against using a non-return valve: http://shetlandf4.wordpress.com/bilge-pump/.
Yes, but the first tiny bit of grit or hair lodging in the seal of the NRV will break the perfection of the non-return seal, and the water in the pipe will very slowly trickle back. If you have a big wide bilge base it is unlikely to be enough depth to re-trigger the float switch, but if a small sump and a long pipe run the float switch will trigger the pump again, on and on till the pump dies or the battery is flat.If there's enough water in the delivery pipe to raise the level in the bilge when it drains back to a level that switches the pump back on, the pump will continue to cycle on and off till your battery runs down. So you're forced to fit a nrv. (in my opinion)
