Non Boaty - house decorating question
tarik
27 Mar 2004
Broadstairs Kent
Have bought number one daughter a small flat whilst at Uni, it needs decorating (she wants white walls/ceilings??!!) I have always used a roller for such applications, SWMBO has spoken to our neighbour who has convinced her that a 'felt pad' applicator is better and quicker. Before I suggest he relocates his pad to where the sun doesn't shine, are they better than rollers or not??
Many thanks - David
PeterI
16 Jan 2005
Christchurch
Well, as the weather is no good for boating you might as well be decorating. Have nearly finished decorating every room in the house using paint pads (having had each room re-plastered first). They give a much smoother finish. With a roller the effect is stippled and you get splashes flicked off in all directions. Pads take slightly longer but give a really smooth finish, and no splashes.
If you've then got redundant rollers then you can use them up anti-fouling.
Blue5
16 Mar 2006
Hampshire and Portugal
Rollers every time for speed and a good finish.
Having been involved with decorating for more years than I care to remember I have never had a client complain about the standard or quality of finish using a roller.
jerryat
20 Mar 2004
Nr Plymouth
Agreed. Have tried both and find it difficult (dependant somewhat on paint type) to get a completely even finsh with pads. Rollers are definitely much faster too, and if you loath decorating as much as me - that's a huge factor!!
boatmike
30 Jun 2002
Solent
Agreed. Also the slightly "textured" finish hides minor imperfections in the plaster. For ceilings use an extension pole rather than step ladder /forums/images/graemlins/wink.gif
richardandtracy
27 Jun 2002
Medway, UK
Rollers for speed, without question. If you make sure the house is totally empty first, all surfaces are reasonably sound & use a 12" roller for emulsion and a 4" roller for undercoat/gloss you should be able to complete 2 rooms per day per person. That's 2 coats of emulsion on the walls, 2 coats of emulsion on the ceilings, a single coat of undercoat on the woodwork and a single coat of gloss on top of the undercoat. It's hard work, but possible.
As for all white. I'd suggest it for one room only. My wife & I tried it in our kitchen in our last house, but it actually looked lighter when we put some colour on the walls.
Finally, make sure your brat is involved in doing the work. If she gets hot, sticky & covered in paint helping you she'll be more careful about the decorations and will be less likely to change her mind about the colour later!
Regards
Richard.
Heigaro
13 Oct 2006
Adlington, Cheshire
Used to use pads until I tried a roller. Now, it's a roller for me every time - more even finish, uses less paint and is much, much quicker. /forums/images/graemlins/smile.gif
VicS
13 Jul 2002
Rollers seem to be favourite but are we talking foam or (artificial) lambs wool?
I have always used the latter but foam may give a smoother finish?
Allan
17 Mar 2004
Lymington
I always use roller but the answers above reflect what friends tell me about pads. One friend bought pads and after one room threw all his rollers out. Another friend bought pads and threw the pads away half way through decorating the room. I have never heard of anyone who has tried pads the doesn't either love or hate them! I suggest you buy a load of them and then post back on here saying which camp you are in!
Allan
nyx2k
11 Nov 2005
CHICHESTER
I'm doing the smallest bedroom right now. started with roller and now on pads and finish is much smoother. to do big areas very quickly you can beat a roller but for small rooms i prefer a pad.
