no ships compass - am I silly?
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
the slug came with a massive gimballed and beautifuilly engineered compass that stuck out of a bulkhead
it was obviously from a much larger vessel
after catching the sheets, my knees and my hand on it I soon stopped bringing it out from below and putting it into the bracket.
I started using a handbearing compass and a hand held GPS
The compass now lives in my garage
so I use two gps devices and a hand bearing compass
is there any chance that I might one day sail off the edge
Dylan
sailorman
21 May 2003
Here or thertemp ashore
is there any chance that I might one day sail off the edge of the sea
Dylan
as long as the HH can be used to steer by no probs
Pleiades
3 Apr 2006
Fowey
Garage steering compass
You are however well prepared for the next big storm - you will be able to steer a perfect course when your garage blows away, provided of course that you have had the additional presence of mind to be securely harnessed to a suitable stong fixing point.
Robin
Pleiades of Birdham
MXWQ5
johnalison
14 Feb 2007
Essex
It depends on what sailing you do. I get the impession that bouncing off mud banks and dodging the odd seagull is your kind of thing, in which case a steering compass may be a luxury. If you are happy to put up with the chance of having to helm while squinting across a hand-bearing compass when the fog comes down, you're welcome. I think that having a compass to glance at occasionally can be useful, if only for spotting wind-shifts as they happen. Mine also occupies a hole that would look very naked if the compass weren't there.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
The edge - be very careful as this is where the wild things are and rumour has it sink boats ......
For your mud hopping a hand bearing is ok. A way of mounting it may be handy for constant use in fog, etc. I suspect that you could make something up with gaffer tape and cable ties !
fireball
15 Nov 2004
I can't remember the last time I "steered to compass"
It's in the most stupid place ever - on the binnacle in front of the wheel ... How can I see that properly when I'm sat beside the wheel and watching the genoa ... ?
In fact, last time I did try to steer to compass I found that it was too close to me (different boat - but same position) and therefore was difficult to use. Put it further away so you're not constantly shifting your focus from near to far and it becomes much easier ...
SAWDOC
24 Feb 2008
Ireland West Coast
Robin
Pleiades of Birdham
MXWQ5
:D:D:D:D
Salty John
6 Sep 2004
UK
www.saltyjohn.co.uk
Dylan, you're dicing with death once again! This is almost as foolhardy as boiling sealed cans on your stove. Without the compass, how will you know where you're going, or where you've been?
You're getting too old to keep taking these foolish risks. Stay at home and build a punt, or something.
Pleiades
3 Apr 2006
Fowey
And what choice of anchor would the panel recommend Dylan fits to his garage should he wish to slow progress downwind at any point on the voyage? I doubt if garages heave too particulalry well..... unless of course it is an average white mass produced sort of flat bottomed garage, in which case it will perform sparklingly in the meerest puff of breeze....
Robin
Pleiades of Birdham
MXWQ5
dylanwinter
28 Mar 2005
Buckingham
rain
You'll be fine....until it rains eek
hand bearing compass is waterproof, gps waterproof, helm waterproof.
the good thing about the hand bearing compass is that you can move it to a place on deck where it is close to your eyeline - say when watching the sails
and I wonder - could you really sail better course using a big old compass that you could using a small good quality handbearing compas
provided you had it in the right place and not right on top of the battery compartment for instance
as for the duck punt and garage.... first coat of paint just gone on - garage still in need of repair work
I swore I would never build another boat and here I am having great fun building it small and dirty
very excited about the much expected arrival of oppy rig for test sail after Christmas on local clay pit
Dylan
Dylan
creeksailor
6 Feb 2011
creeksailor.blogspot.com
I have used a handheld as a main compass for a few years now with no probs.
Good luck with the punt. They are spot on for the mudflats and getting in those little nooks or hiding behind that tuft of samphire to watch the birdlife. Sharpen your chisels and use west on your scarf:) Although they look simple enough to build I was fortunate to have John help me build my punt in his boatshed.
Best.
Tony
westernman
23 Sep 2008
Costa Brava
www.devalk.nl
We have a steering compass. It only comes out at night when we are well offshore (i.e. only stars/moon as points of reference). The crew on watch look at it from time to time to make sure the autopilot is not playing silly buggers (which up to now it never has).
I can't bear the thought of sailing through the night in the wrong direction.
Seajet
23 Sep 2010
West Sussex / Hants
Dylan,
your Hand Bearing compass is probably not illuminated in any user friendly way to steer by in poor vis'...
I was once on a boat with a bulkhead compass, + HB job, radar, chart plotter & 2 depth sounders ( the latter being much under-rated when combined with a compass ).
The main compass failed very quickly, with the card jammed, but I thought 'I'm a smart-a**e with all the electronics, I'm fireproof'...:rolleyes:
In thick fog the electrics failed and I lost the lot, it was a subtly shelving shoreline contour so nav' judging depth by a line on a spanner - while steering by a hand compass up to my eye, and engine on, while keeping a lookout - to find the harbour entrance was out.
Had an unpleasant night at anchor just off a main channel; with a proper functioning illuminated main compass ( and a watch, or ideally a trail log, I do use it ) I'd have been tucked up warm in bed.
Norman_E
15 Mar 2005
East Sussex.
Dylan
I have seen those old charts made in the days before the earth was round. I think you are quite safe as long as you keep turning left! :D
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
We fitted a Plastmo bulkhead compass into a spare washboard because we felt guilty that we didn't have an old-fashioned steering compass - but since we did that we have never used it. We use the GPS, chartplotter or Navik to steer. It is however nice to know that we have a proper steering compass should the need arise. There are two wires with a plug on the end stashed away that can be connected to light the compass up at night.
- W
